ArcGIS Pro 2.4.2: “view cache status” tool is not available,
10500
23
10-21-2019 12:33 PM
Status: Open
JamalNUMAN
Legendary Contributor
It would be great if the “view cache status” tool gets available in ArcGIS Pro
23 Comments
RobinCCOB
Has anyone figured out how to do this yet? I'm currently on Pro 2.6.2, can't upgrade past that yet unfortunately.
andrei_ste
I discovered that you can view the cache status in ArcGIS Server Manager:
To be honest I liked more how things were organized in ArcGIS Desktop.
RobinCCOB
Thanks for the tip @andrei_ste ! I still don't like the fact that I have to open server manager just to view the cache status while running the geoprocessing tool to manage the cache status, but at least it's possible. I agree with you though, I preferred the options available in ArcGIS Catalog. Job status completion percentage alone is not enough. I'm still hopeful they will add that option into Pro.
JamalNUMAN
This appears not to be available in 2.9
JamalNUMAN
Thank you andrei_ste for the input. It’s good to know that this tool is available anyway. We would love to have it in Pro
SamHudson
@JamalNUMAN  I agree completely.  I was just rebuilding the cache for one of our large basemaps and the only place I could find cache status information was in ArcGIS Server Mananger.  The Job Status queue is not reliable nor comparable to the information that Arc Catalog provides.  The cache status window visible in ArcGIS Server Manager should be accessible for any cached service in ArcGIS Pro.
andrei_ste
I discovered that when you publish a map or image service and you set up the cache properties, the map or image service is added to the Job Queue where you can view the cache status like the documentation says: https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/sharing-job-status.htm
If you click the Jobs button in the Publish Image or Map Service:
The Job Queue panel will open and you can view the cache status over there with estimated time remaining and percentage completed:
I am using ArcGIS Pro 2.9, but I think this option is available also in earlier releases.
MaximeDemers
I am using Pro 2.9 and I want to stop the caching process. How can I do that?
andrei_ste
@MaximeDemers from the Job Queue
MaximeDemers
@andrei_ste That's right if ArcGIS Pro is opened. What if I have launched the caching process from a script?
Yes I could stop the CachingTool instances, but that's not convenient if I have more than one caching process running simultaneously.
Esri should provide the same way of managing cache than before. That's not user friendly at all in my opinion.
