ArcGIS Pro 2.4.2: Pro fails to respect unchecking “create folder for a project” option when choosing the “without a project template” option
870
10-31-2019 11:01 AM
Status: Under Consideration
JamalNUMAN
Legendary Contributor
I observed that Pro fails to respect unchecking “create folder for a project” option when choosing the “without a project template” option; it keeps saving the aprx file in a folder
For example, in the screenshots below, the P1.aprx file is intended to be saved in the Q folder. The Pro created P1 folder and inside it the P1.aprx file is saved despite the fact that the “create folder for a project” option is unchecked.
In addition to that, the Maps item is not displayed by default. It appears once the “New Map” is created
Is this much of confusion by design?
3 Comments
JamalNUMAN
I tried the Pro 2.5 Beta 1 and found out that this idea is not implemented. What I wanted here is to get the following implemented as the “without a project template” option is selected:
  1. To get the map item created by default
  2. To get the aprx file created without folder when saving the project
Why this should be challenging?
NaicongLi
nadja
ArcGIS Pro allows in "Options" >> "General" >> "Create project" to uncheck "Create a folder for the project". This works fine if the project is started with a template like a Map, Catalog, etc. However, if the Option "Start without a template" is chosen, you cannot just save the .aprx file in your pre-defined project structure. Using "Start without a template" and saving the project later will always create a new project folder (let's not discuss the default naming policy).
We strongly suggest to honor the chosen settings and to NOT create a project folder, even if one has started without a template.
See also RobbynAbbitt ‎'s comment from 02-15-2023 07:28 AM in this question https://community.esri.com/t5/arcgis-pro-questions/save-arcpro-project-without-a-new-folder-created/...
