Allow ArcGIS Pro to rename lyrx file in catalog pane
2249
07-29-2020 07:51 AM
Status: Implemented
DuncanHornby
MVP Notable Contributor
In ArcGIS Pro 2.6 you cannot right click on a lyrx file and rename it from the context menu as you can on datasets, see image below
It is possible to rename the lyrx file using the Rename geoprocessing tool, but obvious this would be a simple improvement to the ArcPro GUI as well as bring consistency to expected behaviour.
4 Comments
KoryKramer
Thank you for submitting this, Duncan!  It is a valid request.
I just wanted to make sure that you were aware of the functionality added in 2.6 where you can get directly to the folder containing the file.  While I understand it isn't what you're requesting in this idea, it might help facilitate renaming the lyrx.
DuncanHornby
Obviously as you say not quite what I was suggesting but I can see that being quite useful for other scenarios.
KoryKramer
KoryKramer
This is implemented in ArcGIS Pro 2.9.  See Ideas in ArcGIS Pro 2.9 and go directly to 1:43 in the video for a quick demo.
