Contents > Data > Export to Excel
1203
16
08-20-2025 08:27 AM
Status: Implemented
Bud
Esteemed Contributor
It would be great if we could export to Excel directly from the Contents > Data menu. Add a new "Export to Excel" option under "Export Table".
16 Comments
LadislavJeník
Add another option to select the type of exported file to the table functionality in ArcGIS Pro. Export data to MS Excel (XLSX) format. Currently, this can only be done to DBF format. In geoprocessing tools, data can be exported to XLSX format, but it is not possible directly from the table.
LadislavJeník
It would also be a good idea to add a checkbox for "Use domain and subtype description" when exporting.
Possibly other possible options, as is the case with the geoprocessing tool "Table To Excel".
BSBlagojevic
Yes! It’s crazy to export in old dbase table?!? Is anyone use this today?!?
SSWoodward
Thanks for this Idea @LadislavJeník .
Does the Table to Excel GP tool satisfy your request or is there some specific functionality that is missing for your workflow?
AlfredBaldenweck
I think their point is that it'd be preferable to have that capability by right-clicking on the item in the contents pane -> Export
SSWoodward
Status changed to: Open
Thanks @AlfredBaldenweck,
I updated the name of the Idea to match the intent.
LadislavJeník
Thank you @AlfredBaldenweck, it's precise.
Thanks @SSWoodward for the edit name of the Idea. I believe ESRI will incorporate it into ArcGIS pro. 😉
SSWoodward
We do our best to incorporate feedback!
If you use this tool a lot, my suggestion in the mean time would be to add Table to Excel to your Quick Access Toolbar. This would allow you to access it in fewer clicks than if it was in the right-click export menu.
LadislavJeník
@SSWoodward
I see. Thanks for the suggestion. It's also an option.
But I would prefer if ESRI incorporated the export into the standard spreadsheet environment.
SSWoodward
@LadislavJeník If this idea were implemented, it would still be a different tool. The enhancement would be adding the separate Table to Excel tool as a new option in the context menu.  Exporting to Excel requires a different set of input information than exporting to a geodatabase or dbase table.   Is that in line with your request?
