It would be great to have some more options in the the AddRasterToGeoPackage tool in ArcGIS Desktop and ArcGIS Pro. At present, for example, it is impossible to control:
To my knowledge, ArcGIS uses the GDAL library for converting the rasters. Therefore it should be possible to hand the available and applicable options on to the geoprocessing tools.
Agree, Also, bit depth. I loaded a one band 16-bit unsigned integer, came out 4 band 8-bit in geopackage
