Add interactive selection methods to ArcGIS Pro
1353
06-21-2021 01:19 PM
Status: Already Offered
GISAdmin26
New Contributor II
In ArcMap, under the Selection menu, you can choose interactive selection methods such as Add to Current Selection, Remove from Current Selection, and Select from Current Selection. While ArcGIS Pro does allow you to hit Ctrl and click to remove from selection, it is more foolproof to select "Remove from Current Selection" and simply left click on the map. Some of our users have huge selections of parcels that they spend days working on and it would be very risky to have to hit Ctrl first and then click on the map. Also, if you have a very complicated selection, it's nice to be able to Select from Current Selection. It would be great if Pro could have these options incorporated.
4 Comments
KoryKramer
Hi @GISAdmin26
I'm pretty sure what you're asking for is here:
Comparison to ArcMap:
I just wanted to clarify before marking this as Already Offered.
GISAdmin26
@KoryKramerThanks Kory. I didn't know that was there. Perhaps ESRI could make this a little more obvious to users?
Thanks!
Anja
GIS-Chops
Anja,
I posted a tutorial video on the selection tool here - https://youtu.be/Oa7TuxHnsv0
KoryKramer
Thanks, Anja.  I'm marking this Already Offered since the options are available.  In terms of making these easier to find, what would you have in mind to make the interactive selection options and modes more discoverable?
