Access All Editing Tabs When Editing Multiple Symbols
9349
15
01-17-2019 10:35 AM
Status: Under Consideration
ZacharyRoy
Context menus/tabs should not differ when editing a single symbol and when editing multiple symbols in the same feature class.
What I think
When developing symbology, it is often useful to be able to edit many symbols at once. The ability too do so increases efficiency, and ensures consistency in the symbology being developed. While developing symbology, it can be deasy to overpopulate the 'styles' workspace with un-finalized versions of various symbols. For this reason, saving to a symbol to a style is not the preferred method.
The Menus
In ArcMap 10.X, the symbol editor was identical when you were editing 1 symbol, and when you were editing multiple symbols. In ArcGIS Pro, when you are editing 1 symbol you have access to the Symbol Tab, the Layers Tab, and the Structure Tab. However, when you are editing multiple symbols (via 'Symbology' pane> 'More' drop down> 'Symbols'> 'Format all symbols') you only have access to the Symbol Tab.
Current Setup
When Editing a Single Symbol (Unique Values)
Symbology pane when editing a single symbol in ArcGIS Pro 2.0.1 (polyline symbol as example).
Available Options
Feature TypeSymbol Tab OptionsLayers Tab OptionsStructure Tab Options
Point
Scale Based Sizing
Appearance
Halo
Appearance (for each Symbol Layer)
Position (for each Symbol Layer)
Rotation (for each Symbol Layer)
Offset distance (for each Symbol Layer)
Symbol
Layers
Polyline
Scale Based Sizing
Appearance
Line Width
Offset effect (for each Symbol Layer)
Dash effect (for each Symbol Layer)
Caps & Join (for each Symbol Layer)
Symbol
Layers
Polygon
Scale Based Sizing
Appearance
Pattern (for each Hatched, Gradient, and Picture Symbol Layer)
Symbol
Layers
When Editing Multiple Symbols (Unique Values)
Symbology pane when editing multiple symbols in ArcGIS Pro 2.0.1 (polyline symbol as example).
Available Options
Point
Scale Based Sizing
Appearance
Halo
Polyline
Scale Based Sizing
Appearance
Line Width
Polygon
Scale Based Sizing
Appearance
15 Comments
AndrewBarker3
Thanks for taking the time to generate the screenshots.  I can't believe we can't change features that are applicable to all currently selected symbols, like border weight.  It would also be great to not only be able to set this value but also have the option to bump the current weights up or down.  That way, if differing weights are set, they all increment up and stay different sizes relative to each other.
Outline should be accessible regardless of the symbol shape that's applied too.
PeteJordan
Yep this is annoying to have this not part of Pro as it was in ArcMap.  Often I need to do create several mutli-layered symbols that are similar, but a bit different.  It would be so much nicer to be able to do this without having to create styles as it used to be like that's for sure.  I was originally thinking I was missing something, but then was directed to this post...
DanielMatranga
Kory Kramer‌ any update from the Pro team on this request?
KoryKramer
I believe they may have started looking into a design for this functionality, but since that isn't complete, development work hasn't started yet.  We will update the status when there is higher confidence about the work being scheduled for a release.  I realize this is somewhat vague, but that is the update.  Hopefully we'll see this in a near-term Pro release (excluding 2.5 which is coming this month).
DavidWheelock2
Any update on when this will be implemented, @KoryKramer.
This hampers many legends that I build, forcing me to spend much time building the legend from scratch, or going back to ArcMap, building the legend there, saving it to a LYR file, and importing the LYR file to Pro.
Using ArcGIS Pro 2.8.1.
wayfaringrob
Thank you for so thoroughly laying this out - still no further modification options in Pro 3.0.3 (update: or 3.1). This would be a huge timesaver. I find myself not only manually adjusting each individual symbol class, but doing so over and over whenever a tweak is needed. Styles can only help so much.
wayfaringrob
Re:
I agree with you, and this would help: Delete style items from style item picker - Esri Community
Though kudos are disabled, it would help if anyone interested would comment on that post and ask that it be re-opened. The reasoning given -- that they have no plans to make things easier -- defeats the purpose of the ideas site.
MiguelMartinezYordan
When you categorized by unique value, and you select all categorized to customized the symbology (Format all symbols), only a hand full of options are available in the PROPOERTIES tab. Enable all available options.
EdiePunt
alfrenjeru
Looking forward to the possibility to edit outline of a polygon, instead of creating a new one. Sometimes I go to ArcMap, create a new polygon style with the desired outline, then import the new style in Pro. It should be made possible in Pro.
