Updating parcel lines after modifying parcel polygon
780
08-07-2025 11:54 AM
dgiersz_cuyahoga
We used to map condominium parcels with points. When we moved to Parcel Fabric, we converted them to polygons using their minimum boundary area. This worked fine, but the resulting polygons are too small (2 feet by 2 feet). I created larger polygons to replace them with, but are unsure on how to then update the parcel lines which remain at 2' length.
Is there a way to get the 2' lines' geometry updated or do they need deleted and recreated?
#CLE #sloth
AmirBar-Maor
@dgiersz_cuyahoga
I think the answer depends on whether or not you care about the lines.
If you do not care about them, just delete the lines and the points that defined the old 2'x2' footprints, the 'correct' lines and points will be created once you press build.
AmirBar-Maor
@dgiersz_cuyahoga
dgiersz_cuyahoga
Thanks for the reply! We don't care about the lines, they were autogenerated after the 2'x2' polys were created.
#CLE #sloth
