TAB key in ArcGIS Pro 3.0.3 is not working
701
04-13-2023 05:12 AM
ThomasKonzel
@AmirBar-Maor is there a trick to getting the Tab key to work when drawing a traverse in ArcGIS Pro 3.0.3?
Robert_LeClair
Esri Esteemed Contributor
Thomas - in reading the Enter a Traverse documentation, it appears you have to use the Enter key vs the Tab key to move through the COGO data.  I don't know if the Tab will work here.
Robert_LeClair
ThomasKonzel
Thank you for the reply. We just moved from Pro 2.6 over to 3.0.3 and the
Tab key worked. It appears that the Enter a Traverse tool has been changed
to work only with the Enter key somewhere between 2.6 and 3.0.3.
Thank you.
