Importing multiple traverse files? Python Automating?
1049
06-27-2023 01:55 PM
Andrew_Lintz_DRGA
I have a folder with 1200 "ArcMap Traverse Files" in .txt format. Example of two small lines:
DT QB
DU DMS
SP  2618687.126449457 181820.133039019
DD N0-0-0E 0
DD N87-0-0E 0
DD S87-0-0E 0
DD S70-0-0E 0
DD S75-0-0E 1
DD S78-0-0E 1
DD S52-0-0E 1.16227766016838
DD S40-0-0E 2.66867423467692
DD S32-0-0E 3.38859256244759
DT QB
DU DMS
DD N0-0-0E 0
DD N87-0-0E 0
DD S87-0-0E 0
DD S70-0-0E 0
DD S75-0-0E 1
DD S78-0-0E 1
I can import them individually, and each work great... but doing so manually is/will be a pain.  I've tried packing multiple into one file, but despite having a stated Start Point in X Y for each new line, ArcGIS Pro 3.1 acts as if the end of the last segment is the start point. I ended up with a continuous line with only the the first at the correct Start Point location.
Any advise?
AmirBar-Maor
There is no Python API to import ArcMap traverse txt files in Pro. But you could always write Python to parse a text file and create features.
