COGO, Quadrant Bearing Directions in .dbf file, Legal Description
981
7
11-02-2021 11:40 AM
LadyFranciscarKassama
In the ArcGIS Desktop version, I am able to open the .dbf file in excel and see the quadrant bearing directions of a line as it is, e.g. S 1-56-18 W. It's easy for me to write the legal description this way. Is there a way to do so in ArcGIS Pro? When I open up the file its in decimal number format.
ABishop
MVP Regular Contributor
Maybe try adding a new field with a type of text or double?  Then calculate that field using the data from the old field that is a number field.
Amanda Bishop, GISP
Thank you. I tried that but once calculated, it still shows the numeric value of the direction.
ABishop
I looked at why this is happening and you may have to convert the coordinate notation?  Here is an information page on it:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/convert-coordinate-notation....
Amanda Bishop, GISP
I looked into it. But I have a line feature class, which does not have an x, y values. The tool requires an x, y value.
ABishop
OK... I looked at the COGO tools in ArcGIS Pro... you could try importing the .dbf file as a traverse.
https://pro.arcgis.com/en/pro-app/latest/help/editing/import-or-export-a-traverse-file.htm
Amanda Bishop, GISP
I appreciate you looking this up and responding. I was able to export it to a .txt file. This works but would like to see how others would approach this as I am trying to transition from desktop to Pro. Thank you!
ABishop
OK great!
Amanda Bishop, GISP
