Change projection of a Parcel Fabric in ArcGIS Pro 3.3
2165
10
11-05-2024 07:56 AM
MarkWasdahl1
This topic shows up in a 2019 post but an update would be helpful. We have two separate Parcel Fabrics but each has a different projection and we would like to merge them. Obviously, they must be in the same projection. Does the Parcel Fabric require special consideration(s) when re-projecting?
MarkWasdahl1
I listened to you and exported all feature classes to a fresh correctly projected file geodatabase. Everything appears to be in the correct location and the geodatabase is fully functional. Thank you for your guidance.
