ArcGIS Pro 2.5: How to fix “must have a record” error in the parcel fabric topology?
1655
05-23-2020 01:51 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to fix “must have a record” error in the parcel fabric topology
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Create parcel fabric records—ArcGIS Pro | Documentation
which notes
Every parcel in the parcel fabric must have an associated record. When validating the parcel fabric, parcel features with no associated record will result in Must Have A Record errors.
which links to methods on how to validate and fix errors
Validate the parcel fabric and fix errors—ArcGIS Pro | Documentation
Fix the Must Have A Record error
Parcel features (points, lines, and polygons) should have an associated parcel record.
Anything in your process that seems off?
... sort of retired...
DanPatterson
which notes
JamalNUMAN
Thanks Dan. Right, I need to assign the new added parcels to a record either with the command “assign to active record” within the topology window or with the “assign selection to record” command in the “manage record” pane.
Jamal Numan
IrvanSalim
Hi Jamal NUMAN‌,
As you may have figured out, when fixing features with "Must Have A Record" errors, you need to make sure that you have a record that is currently active if you wish to fix it by the "Assign To Active Record" option, otherwise it will be greyed out. You can, however, fix them by assigning the selected parcels to a record through the Manage Records pane (even if there is no active record at the time).
Cheers,
Irvan
JamalNUMAN
Thank you for the useful input, Irvan.
Jamal Numan
