XSL for GetFeatureInfo
2885
03-21-2016 09:53 AM
OscarDiago_Alonso
Hi
I'm building a XSL template to customize the GetFeatureInfo of a WMS service.
I have to adapt the XSL developed for the HTMLPopup of ArcMAP . In that file I have the following:
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format" xmlns:msxsl="urn:schemas-microsoft-com:xslt">
  <xsl:template match="/">
       <html>
            <head>
                 <META HTTP-EQUIV="Content-Type" CONTENT="text/html;charset=UTF-8"/>
            </head>
            <body>
                 <xsl:variable name="myField" select="FieldsDoc/Fields/Field"/>
                 <xsl:variable name="myColumn" select="$myField[FieldName='test']/FieldValue"/>
             </body>
       </html>
  </xsl:template>
</xsl:stylesheet>
I have "translated" it into:
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:esri_wms="http://www.esri.com/wms" xmlns="http://www.esri.com/wms>
       <html>
            <head>
            </head>
            <body>
                 <xsl:variable name="myField" select="esri_wms:FeatureInfo[1]/esri_wms:Field"/>
                 <xsl:variable name="myColumn" select="$myField[esri_wms:FieldName='test']/esri_wms:FieldValue"/>
             </body>
       </html>
  </xsl:template>
</xsl:stylesheet>
Is this correct?
Thanks!!
