Where is analysis option?
2451
6
02-06-2024 11:37 AM
JB02062024
Hello,
Where is the analysis option within map viewer?  I hear it's in the settings toolbar, but do not see it.  This is my settings toolbar:
Am I missing it?
Thanks!
Jessica
bbollin
Hi @JB02062024  it should be visible. Are you signed into your org account and do you have the correct permissions to perform analysis? https://doc.arcgis.com/en/arcgis-online/analyze/perform-analysis-mv.htm
JB02062024
It must be a permissions issue- thanks!  I will check on that.
RussRoberts
Esri Notable Contributor
Hey Jessica,
You will want to check with your admin for your org to see if you have a role that supports performing analysis or go under your profile settings > licenses > click on the i next to role and see if Spatial Analysis is listed.
https://doc.arcgis.com/en/arcgis-online/analyze/licensing-analysis-mv.htm
JB02062024
Thanks so much for your response- I will look into that.
AmandaRing
If you do have the correct privileges, two other possible reasons could be that you don't have enough credits, or you don't have any hosted layer published to your organization.
Check out this blog to learn more: https://community.esri.com/t5/arcgis-online-blog/faq-why-don-t-i-see-the-analysis-button-in-map/ba-p...
Amanda
Product Engineer - Web Analysis
JB02062024
Ok- Thank you for weighing in- I do think it's a permissions issue, and will check into that.
