When sharing web feature layer from contents from ArcGIS Pro to Portal, get Unable to retrieve the caching status. What workaround for this in elegant schemes ?
1314
01-18-2018 03:35 PM
FranciscoCosta1
When sharing web feature layer from a 3D layer in contents, from ArcGIS Pro to Portal, get Unable to retrieve the caching status. Although the publish status is succeded, and the layer gets shown in Portal, when added to a scene it will display "Scene service is missing root node." and layer is not displayed, what is a workaround for this in ArcGIS pro 2.0 ArcGIS Enterprise w/ portal 1.5 accordingly ?
FranciscoCosta1
Ok since, more people had this question. Usually what you need to do is make sure this check list is fullfilled:
> you have arcgis pro licensed well
> go to DataStore tools folder, and using prompt CLI describedatastore, everything should be ok, if not try to restart your datastore. If that does not work check documentation or contact esri because your configuration maybe not working.
FranciscoCosta1
