What is the difference between a "Hosted Feature Service View" and "Save As New Layer"?
624
11-09-2019 05:38 AM
RobBlash
When you go to a Hosted Feature Service's Settings (Overview) page, you have the option to "Create View Layer". I'm familiar with the concept and I understand what's going on here.
However, on the Visualization tab you also have the option to "Save As New Layer". What is the difference between doing this (aside from the option to save a single layer?) and creating a view?
Based on Create hosted feature layer views—ArcGIS Online Help | Documentation I'm taking a guess that you have more granular control over a HFS View as compared to the New Layer option. Am I missing anything else?
The description in "My Content" is different also.
by Anonymous User
Not applicable
Hi Rob Blash‌ you are right, you have more granular control specifically over the editing, cache settings, the view definition and a few others as well.
When copying/saving a layer with this workflow Copy and save layers—ArcGIS Online Help | Documentation the saved layer will have the same editing properties as the original Hosted Feature Layer as well as contain the same fields as the source. However when you create a Hosted Feature Layer View you can make it non-editable while the source remains editable, and also choose to hide fields:
This is a common workflow for Hosted Feature Layer views - maintain the Hosted Feature Layer as shared to only editing groups for organization members, then created publicly shared non-editable views.
Hope this helps,
-Peter
RobBlash
Thanks for this info
