What is causing this? Error - Value Type is incompatible with the field type. [CreationDa]
4782
9
11-16-2017 08:29 AM
MatthewKrueger
When I go to create a shapfile. I get this Error message. The value type is incompatible with the field type. [CreationDa]
Any thoughts on how to fix?
by Anonymous User
Not applicable
How are you creating the shapefile?
MatthewKrueger
Yes, I go to export data and click export to shapefile and it tries and then it gives that error.
Matt Krueger
Transportation Program Specialist 1
District 8 Willmar/Marshall/
Hutchinson/Montevideo
507-537-2063 (office)
320-212-9719 (cell)
by Anonymous User
Not applicable
How did you publish the data? Are you able to share the source data?
MatthewKrueger
I have not published the data. It is just sitting there, I had a request for the shapefile from it. I’m new to using the online version.
Matt Krueger
320-212-9719 (cell)
by Anonymous User
Not applicable
If it is publicly shared with everyone can you paste the link on this thread?
MatthewKrueger
I do not have it publicly shared yet. My data is collected but there is more data that needs to be collected. There is just a group of people that would like to move my data into another system we use.
Matt Krueger
320-212-9719 (cell)
by Anonymous User
Not applicable
Do you have the ability to open a Support case? If not please let me know.
KellyGerrow
Esri Frequent Contributor
Hey Matthew,
Is Editor Tracking Enabled on this Layer?
Manage hosted feature layers—ArcGIS Online Help | ArcGIS
Are you able to export and open it as a file geodatabase?
What is the CreateDa fields used for? Is It a date field?
-Kelly
RagnhildTveit
New Contributor II
I had the same problem. Unfortunately the CreationDate field cannot be deleted. I found a workaround, though: clicking on the hosted feature layer in AGOL and choosing "Open in ArcGIS Desktop" from the menu on the right. I then exported the layer to a shapefile in ArcGIS Desktop, and chose to publish and overwrite the existing service in AGOL. This solved the problem, however it would be useful to know what causes this.
