Hello
In AGOL when I click in a WebMap and also in EB to a feature the popup window does not shows the Feature class (layer) name.
How can I enable it?
You can add that to the popup title in the Configuration dialog.
Hi @SanchezNuñez!
As @KenBuja demonstrated, there is a Title option in the Pop-ups settings box. You can either add a static title to this box, such as the layer name (ex: "Roads of Alaska") or you can make the title dynamic, where it changes from feature-to-feature like what Ken is showing in his image. To do this, click the { } box next to the Title textbox and select the field (or fields!) you want to populate the title. In Ken's example, he has static text ("My layer: Site ID") and then a dynamic element ({FIELD_ID}). The dynamic element notes the Site ID of whichever feature he has clicked on. In this case, it was site 6566.
Let me know if you have any questions!
Thank you @KenBuja and @EllieHakariAK
