WebApp Builder will not load
1556
04-27-2021 06:06 AM
DonMeltzMarist
We have a 50 seat license at Marist College, and about 34 students and faculty using the account.
All is well except for when we try to use the WebApp Builder. It simply will not load. We get a blank page. See the attached .png.
I've tried multiple browsers on multiple computers. I've tried accessing the account through two different networks. Same results.
I'm baffled. I don't even know where to start.
ReeseFacendini
Esri Alum
Does your organization have a custom theme enabled?  Or was one setup at some point, then removed?
ReeseFacendini
Esri Alum
DonMeltzMarist
Moments after posting this I found someone else had the same problem with Experience Builder. Solution was to add a color to the header, body, or button property in shared theme.
I added a background color to the header in our shared theme (which was totally blank before), and this solved my  problem.
Strange behavior.
Thank you.
