Visibility scales
3924
10
11-07-2018 06:25 AM
SimonCrutchley
Is it possible to have two sets of visibility scales for layers on a map in ArcGIS online, so that a feature appears at a given scale, then disappears, then reappears again as you zoom further in? I guess I'm asking a pretty unusual question and it wouldn't be a common requirement, but I thought I might as well ask.
Thanks
RobertScheitlin__GISP
The only way I know to do that is add the layer twice, each with their own visibility scales.
SimonCrutchley
Thanks Robert. I suspected as much, but think it might be confusing to users of the final app if a layer appears twice, so I guess I'll leave it on between max and min.
Cheers
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
SimonCrutchley
Hi Robert,
I was planning to leave it open for a day or so, just in case someone, somewhere has ever had to do this and found a way. I suspect not, but don't want to miss any opportunities. If I don't hear by next week I'll mark it answered on Monday.
Thanks
KellyGerrow
Esri Alum
Hi Simon,
You will need to add the layer twice and set specific scales for each layer. As long as you don't use the layer list widget or enable users to turn the layers on and off, the viewer of the app probably won't see two layers.
-Kelly
SimonCrutchley
Hi Kelly,
Unfortunately, it's key to the app that users can turn layers on and off, so I guess I'm stuck.
Thanks for your help
Simon
KellyGerrow
Esri Alum
Thanks for the feedback Simon,
Can you log an idea about your specific need. I haven't heard this request before, so it would be helpful to understand the workflow and if others are looking to accomplish a similar workflow.
-Kelly
SimonCrutchley
Hi Kelly,
This is the situation. I'm making available links to a series of reports on different projects. I have created a centre point and a buffer for each on the map, and ideally I'd like to have just the points showing at the maximum, country scale, zoom; then as you zoom, in the buffers appear and the points disappear, so as to make the map less cluttered. However, when you zoom right in, towards the town or streets scale, then the buffer, which is no longer accurate, would disappear to be replaced by the point again.
Because we have a series of layers, depending on report types, some of which are large landscapes which tend to dominate, it's imperative for users to be able to turn them on and off.
Is that enough detail? I would point you at the live map, but our web page has fallen over
SimonCrutchley
