Viewing calculated field code
676
01-27-2025 04:11 PM
AngelaNesius
Hello, this is my first time posting, so I'm hoping that I do this right!
Last week I created a new field in one of my layers by going to 'Data', 'Add field', and then I clicked on the new field and selected 'Calculate' and chose Arcade.  Not having used Arcade before, I referred to ArcGIS's Resource section and other online tools and found the code I needed to use.  After a little trial and error, I created a code that returned the values I needed.  Very exciting!  However, now that I want to create similar new variables with calculations, I would like to refer back to this code.  Where can I find it??  It's not in the Detailed View, and when I select Calculate, it directs me to what looks like square one.
Where else can I look to find the code that I wrote?  I already invented my wheel and don't want to re-create it.
Thank you!
-Angie
DavidPike
MVP Notable Contributor
That code is gone permanently unfortunately.
