Utilities Symbology in ArcGIS Online
16896
6
07-16-2019 09:10 AM
JoeChaconas
In the June 2019 release of ArcGIS Online, new symbol sets supporting the utility community(water, sewer, stormwater) were added to the ArcGIS Online map viewer. Is there any supporting documentation available to help identify each symbol?
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/whats-new-arcgis-online-june-2...
LanceCole
MVP Alum
Joe,
I had this same question. I attached a PDF list I got from ESRI that is dated June 2018.  It has most of the symbols but there are a few newer on the latest release to AGOL.
LanceCole
MVP Alum
Joe,
DouglasCochran
In addition, here is a blog that describes some of the new symbols for the ArcGIS Online June 2019 release...
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/updates-to-arcgis-online-symbo...
SarahHartholt
Does anyone know if this symbol set is available for use in ArcGIS Pro, and if so, where?
apgis16
Does anyone know how to use these symbols in (newer) Map Viewer?
JasonZurawski
Have you found a way to use the newer map viewer with these symbols?
-JC-
Yes, this reply is years late, but there is an easy in-editor solution, so for anyone with this same question...
You can see the names associated with each symbol by switching from Grid View to List View.
Switching to List View also allows you to search for symbols by name.
Tags (3)
