Using hybrid reference layer with my own basemap issue
1926
04-27-2023 05:50 AM
EdHixson
Hi there
Does anyone know if there is anyway to include the hybrid refernce layer from Imagery hybrid on my own basemap. It seems very long winded to create my own version.
I have tried doing this in pro but cannot change the project of hybrid reference due to it coming from living atlas and not being able to make a copy
Any help would be greatly appreciated
-Ed
TonyContreras_Frisco_TX
If you are using ArcGIS Online or ArcGIS Enterprise, you can use the Map viewer to add the desired sources as basemaps, then save the map.
Keep in mind that existing basemaps, whether they are map image cached or vector tile cached will already have a projection and tiling scheme set. This cannot be changed since all the images or vectors have been pre-generated with the pre-defined projection and scales. Whatever sources you ty to add together to the basemap group will also have to have the same projection and tiling scheme.
