Use a Feature Layer Drawing UniqueValueInfo in the MapViewer as Label
514
10-05-2022 08:24 AM
Labels (3)
RobertoRossi
The Feature Layer Corine Land Cover 2018 vector,  published by European Environment Agency (EEA), in the Drawing Info, Render, UniqueValuesInfo, Label, exposes a Label text value, describing each of the Unique values codes.
Is it possible to use this values as labels in ArcGIS Online Map Viewers? Maybe is possible using Arcade? I tried without success.
The text description is used by the legend, but doesn't appear in any field of the table (it looks like a property, only defined in the rest drawing info).
Example:
Drawing Info: Renderer: Unique Value Renderer:
Field 1: Code_18
Field 2: N/A
Field 3: N/A
Field Delimiter: ,
Default Symbol:
    N/A
Default Label: N/A
UniqueValueInfos:
      • Value: 111
        Label: 111: Continuous urban fabric
Thank you for your help
Roberto Rossi
