URL parameters no longer work with new map viewer
2952
6
01-24-2022 12:49 PM
Labels (2)
ahargreaves_FW
I'm trying to use a URL parameter to search out a uniqueID and highlight the feature in a webmap with a URL parameter that use dot work for a webmap build in "classic".
The uniqueID is created as a string using #Survey123.
The webmap has the uniqueID field included in its searchable layers.
However, the url parameter shown below now no longer works since migrating the map to the new map viewer:
https://xxxxxx.maps.arcgis.com/home/webmap/viewer.html?webmap=cxxxxxxxxx9?find=0xxxxxx5
RussRoberts
Esri Notable Contributor
JohnCoddHere
That is frustrating!
John Codd (Here)
JeremyNickel
At this point, it feels less like progress and more like forced compliance through broken backward compatibility. Esri used to be a tool that made my job easier—now it’s a constant cycle of chasing bugs and rebuilding work that already functioned. That’s not innovation; that’s inefficiency.
SzuNyiapTang
Hi @ahargreaves_FW
According to the documentation, it should work for both Map Viewer.
for the new Map viewer https://xxxx.maps.arcgis.com/apps/mapviewer/index.html?webmap=xxxxx&find=xxxx
View this example in Map Viewer
Cheers,
Tang
Cheers,
Tang
ahargreaves_FW
@SzuNyiapTang but it doesn't work - hence why I posted.
The example you link to is searching for an address searched against the esri geocoding service. My example looks to search an attribute in a layer included n the webmaps search settings. If I've done something wrong, or misread the documentation, please let me know.
RussRoberts
ahargreaves_FW
hmmm...OK, thanks @RussRoberts  for sending me down the right path. So this was interesting. Here's my theory:
  1. Before posting this thread I had manually edited my webmaps JSON to include ObjectID and GlobalID as search parameters in an attempt to use those:
"search": {
"disablePlaceFinder": false,
"enabled": true,
"hintText": "Place or Address",
"layers": [
{"field": {
"exactMatch": true,
"name": "objectid",
"type": "esriFieldTypeOID"
"id": "xxxxxxxxx"
"field": {
"exactMatch": true,
"name": "globalid",
"type": "esriFieldTypeGlobalID"
"id": "xxxxxxxx"
2. Once they failed to work I established a UniqueID calc’d through Survey123.
3. I updated the webmap to use that in it’s search criteria instead. But it never did. Hence this post.
4. Upon checking the JSON for the webmap it appears that, perhaps by previously manually editing it,  step #3 above never took. And the webmap never actually had my UniqueID set as a search criteria in it’s JSON, despite showing me it did through AGOL GUI.
5. I manually removed ObjectID and GlobalID from the JSON, and manually added in UniqueID….voila! it works.
