Uploading Large Datsets to AGS Online
1052
12-05-2012 06:00 PM
ShaunWeston
Having quite a few issues working with larger datasets and ArcGIS Online.
I have a map document with a 1.72GB feature class in it of polygons in WGS and I want to create a feature service in AGS Online. I go through the Share As bit in ArcMap and publish this service to ArcGIS Online from an Amazon EC2 instance. This starts loading and sits at this screen for at least an hour with no indication of how far along it is:
[ATTACH=CONFIG]19736[/ATTACH]
This finally finishes and I get this error:
[ATTACH=CONFIG]19737[/ATTACH]
I have a look in the Results and it shows a unspecified 9999 error, which is of no use!
I have a look my AGS Online account and there is a service definition file there that is 380MB but no feature service. So it's completed half of it?
So I click on the service definition file and publish that, again it says publishing with no indication of how far through, so just sits on this for a couple of hours then I get this message:
[ATTACH=CONFIG]19738[/ATTACH]
The user I am logged in as is a Publisher. I re-try publishing the service and it works the second time after waiting another couple of hours.
When I try creating a feature service with smaller data (around 10-20MB), it only takes a couple of minutes and completes successfully, but trying this with larger datasets is very difficult with unhelpful error messages. So just wanting to know what is going on with all this?
Workmates of mine are having similar issues with upload failure etc.
MikeMinami
Esri Notable Contributor
Can you elaborate on what you mean by publishing from an Amazon EC2 instance?
Are you saying that sometimes publishing fails, but other times, the same exact data publishes fine?
The error messages are quite vague so it is hard to figure out what is going on. It seems to be failing in the transfer of the data.
Mike
by Anonymous User
Not applicable
Original User: WestonSF
I used a Amazon EC2 instance as the "desktop" computer, so all the data was on there and did the publishing from there in the hope that the upload would be a lot quicker than from my workstation.
Yes sometimes the publishing worked and sometimes it didn't and yes the error messages are incredibly vague. I ended up getting it to work after about five attempts. It's pretty much put us off using ArcGIS Online, for large datasets anyway.
