Upload Service Definition fail. Error 999999
3445
08-23-2012 11:16 AM
RandallClark1
Hi i am trying to upload Service Definition file to AGOL but ever time i try, the tool fails and gives the 999999 error. Everything about the file seems fine and the only thing i can think off is that my trail subscription expired and i waiting to get it renewed. Could this be what is causing my errorr or is there something else to look at?
Attached is the error log.
correction the account is current
Nevermind it works now
jennyyan
How big is the data? If you downsize the data a little bit, for instance, exporting a part of the dataset and then publishing again, do you get the same error message?
JeffGiesler
Has anyone else had this error.  We are getting it on multiple computers.  I have tried to uninstall and re-install the SP.  The error report comes up as a general function error.  Any help or ideas would be great.
Cheers,
Jeff
MikeMinami
Esri Notable Contributor
Jeff, we would need more information in order to reproduce the problem. It may be related to the size of the data, permissions, or the type of data being published.
This would be a difficult problem to debug through the forums. I suggest you contact Esri Technical Support.
Mike
