Updating Web Map from ArcGIS Pro
4842
11
04-24-2024 06:37 AM
TylerT
I have published a Web Map from ArcGIS Pro.  What is the recommended workflow to update this Web Map from ArcGIS Pro, given that is appears the same publish tool will not over write the previously published Web Map?
Thank you,
Tyler
Dana_FSC
Trying to bump this up - still having this (remarkably stupid and frustrating) issue. What am I doing wrong?
davedoesgis
I was probably just undercaffeinated, but I had a heckuva time figuring out how to save the webmap back to the portal (I'm using Enterprise, but I think it's the same as AGOL). As usual, it was cleverly hidden in plain sight in the ribbon. Here is how I did it.
https://community.esri.com/t5/arcgis-enterprise-questions/copy-symbology-to-webmap-layer/m-p/1669828...
