Updating Data effects only some fields
682
07-02-2024 12:03 AM
WaverleyCouncilGISTeam
I am attempting to update a feature layer through the "Update Data" function. I have verified that the input shapefile is formatted exactly the same as feature layer I am attempting to update. The majority of data is updated, however, there are a few fields where no data is updated. I have attempted to do the same through ArcGIS Pro's "Append" tool. I receive the same result, the same fields do not update with the input data.
Can anyone let me know where I should begin trying to update the data?
Kind regards,
Waverley Team
DanPatterson
what is the field type that isn't being updated? (text, integer, double, date? other?)
... sort of retired...
It's a text field. However, many of the fields that have updated are text fields as well.
I have solved this issue by creating lists, and then inserting a separate feature layer's data through FME. I did this as creating the domains still didn't fix this issue when using the "Update Data" function.
