Updated Visualizations Features
1820
8
04-02-2025 11:04 AM
LonerockAdmin
Hi, is there any way to get some updated Visualization features? On some other datas, there are more options, not so much on this layer. Is there a way to update this layer to provide more visualizations?
or am I going to have to reupload it?
EmilyGeo
Hi @LonerockAdmin
After you style the layer in Map Viewer, you can save those settings to the layer using the Layer options menu.
EmilyGeo
Hi @LonerockAdmin
Have you tried using Map Viewer instead of Map Viewer Classic?
LonerockAdmin
This is in the Visualization tab for the Shapefile. There is no way to switch between Classic and Mapviewer.
EmilyGeo
Hi @LonerockAdmin
I can't repro on the Visualization tab.
What type of layer is this? Is it a hosted feature layer?
LonerockAdmin
Yes, it's a hosted feature layer. I've had no problems with newer ones that I've uploaded to my Org. This one seems to be stuck, only wanting to display in MapViewer classic.
EmilyGeo
Are you able to open the layer in Map Viewer?
LonerockAdmin
Yes. But I can't change the symbology for it through that layer. If I do it through Visualization, it sets it for when we import that layer into ArcGIS Pro. If we open it as a Map Viewer, it just wants to save it as a new map.
EmilyGeo
Hi @LonerockAdmin
LonerockAdmin
Awesome, that worked. A bit clunky on how to do it, but it worked.
