Unnamed "error" after every attempt to use "analyze" in ArcGIS Online
587
7
08-10-2022 10:45 AM
DavidM1
Every time that I try and use 'perform analysis' in ArcGIS online, (while in map viewer classic), an unnamed and unnumbered error occurs. I can't seem to find the issue on my side. It might have something to do with the fact that my data was extracted from an excel document using addresses and cities, rather than coordinates?
 This is an image of the error message (how does this help me!)
Thanks to anyone that helps with this issue,
David
DavidM1
It happens even while trying to extract data from the map, so it seems to be a data issue, if anything? But how can I solve this?
JayLarsen
Occasional Contributor II
OH....in that case, do you have the rights to extract data?  It is a specific right that must be granted on layers, etc.
JayLarsen
I get this occasionally as well.  Always at the wrong moment. I can never tell if it is me and my corporate firewalls or ESRI being weird.
Logging in and out of AGOL and/or the computer sometimes clears it. Sometimes just keep hitting "redo" button or setting up the calc again does it.
Very frustrating! Good luck!
DavidM1
Thanks, I will try doing this.
DavidM1
Your fix didn't seem to work. The only thing I can tell which could affect this is that when I add my layer, which is to be analyzed, to arc map viewer classic online, a message is displayed which says that not all features of the map are supported by map viewer classic. Maybe this has something to do with it?
DavidM1
https://community.esri.com/t5/arcgis-enterprise-questions/edit-portal-services-url/m-p/430617/highli...
This link shows a previous issue with the same error message; however, all the hyperlinks provided by the Esri staff seem to be outdated.
AmandaRing
Hi @DavidM1,
Are you able to share the data and steps you are following? I'd like to see if I can reproduce your error.
Amanda
Product Engineer - Web Analysis
