I'm unable to "update data" on any of my feature layers. This has changed only in the last day or two. Normally if I need to add features to my layers I can hit the "Update Data" button on the summary page for the layer and then upload a zipped shapefile containing my new features. The menu has changed some and now I'm presented with 4 options. Selecting the "Add Features" option and then the Next button takes me to a blank window. No place to upload a zip file or even any text on the menu. Just a "Back", "Next", and "Cancel" buttons along with the normal Close Window X on the top right. Next button doesn't do anything. What's broken?
Reuben.
I am now able to get past the upload portion of the "Update Data" "Add Features" however that tool eventually gets to prompt asking to match fields. It gives an error "To Append data, provide one or more matching fields". This is not the same behavior as before the AGOL "upgrade".
This particular data has no fields to match, I just want to be able to append new features with blank data. I was able to do this previously.
Previously I could simply upload a zipped shapefile containing polygons with no attribute data (these are exported from our CAD systems) and append them as new features with blank attribute data. Then I update the attribute data in ArcGIS. I expect this is how it should work, but it won't get past the screen asking for matching fields. See screenshot.
We are having the same issue. I can use Append tool in ArcGIS Pro and on the Feature Service 'Update Data' and the number shows more records added (But not the complete amount) When I scroll down in Pro it reverts to the original number and when I look at the data tab it scrolls but everything is blank until it resets and it's back to the original record count.
