Unable to overwrite hosted feature layer
4264
8
11-02-2021 08:49 AM
ChristinaHoddinott1
Hello! Every time I try to overwrite a particular hosted feature layer using ArcMap I get the message "Unable to overwrite service- Problem retrieving configuration from the server".
It's not an issue with a missing service definition file so I'm at a loss. I have even deleted the feature layer completely and republished it as new but I still get the error when I try to overwrite it. What could the issue be here?
Tags (3)
ABishop
Have you tried republishing it as a different name?  It could be that the service is stuck on AGOL as that name or something.
Amanda Bishop, GISP
ABishop
Hello @ChristinaHoddinott1
Did you make it authoritative or add delete protection to it in ArcGIS Online?
Amanda Bishop, GISP
ChristinaHoddinott1
No.
ABishop
Have you tried republishing the service?  I did a google search for the error you provided and it seems the dependencies may have been lost or moved?
https://support.esri.com/en/technical-article/000013575
Amanda Bishop, GISP
ChristinaHoddinott1
I've tried multiple times completely deleting and republishing it to AGOL but still have the same problem.
ABishop
Amanda Bishop, GISP
ChristinaHoddinott1
oh my goodness that worked... thank you so much!
ABishop
You're welcome!  Glad I could help 🙂
Amanda Bishop, GISP
ABishop
Also, I did a search for this issue in the ESRI bug report online and it was just updated yesterday:
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5NTI1MQ==
Amanda Bishop, GISP
