Unable to import this shapefile. (Cannot call method 'intersects' of undefined)
4307
09-16-2013 12:12 PM
EddCochran
Hi, I am getting the error message designated in the title when trying to import a point shapefile with a few hundred points to a          webmap in map viewer online. can you please explain this to me? I have attached the shapefile.
Thanks
TimWitt
Edd,
try projecting your data into WGS84 using this tool and see if that data can be added.
Hope this helps!
Tim
EddCochran
Thanks for the timely response timw1984 but unfortunately I am still having the same issue. Any other advice?
AkosKisreti1
The problem is that your shapefile is Multipoint. You have to convert it to Point.
You can do this with the Feature to Point tool. After converting to point I was able to import it to a web map.
I recommend what Tim said earlier, to project your data into Web Mercator (Auxiliary Sphere).
Akos
EddCochran
Thank you for your help!
TimWitt
Edd,
Don't forget to mark Akos answer as the answer, so that other people with the same problem know which post help. I'm glad it is working now!
Tim
