attribute data displays zeros
1017
09-17-2013 06:21 AM
madigalediga
hi
after mistakinly using the field calculator, data on 1 field on the attribute table rename all the records with zeros(0)/nulls.how do i recover the correct data
you help will be highly appreciated
thanks
TimWitt
Did you do this in an edit session? If so, did you save your edits? If you did that, then it is permanent, this is the same if you calculated data out of edit.
TimWitt
