Unable to export a large hosted feature service with attachments to a file geodatabase
1234
08-10-2022 03:16 AM
Ageosutilisateur2
We have a large data collection project with attachments (more than 500 000 ) and we can't downloaded it as a file geodatabase ..
Please is there a method other than the below to download this large dataset from AGOL as a file geodatabase?
https://support.esri.com/en/technical-article/000015786
https://support.esri.com/en/technical-article/000012336
Thanks
JosephHilliard94
Ageosutilisateur2
yes but it takes more than 5 hours and does not show the download link..
JosephHilliard94
Only other thing that has worked for me on large layers is to use 'create' in the managers module and specify download - https://developers.arcgis.com/python/api-reference/arcgis.features.managers.html#arcgis.features.man...
MicZatorsky_AEC
Do you have ArcGIS Pro?   Find the hosted feature layer in Catalog > Portal, Add to Map,  then from the Map Contents, right-click DataExport Features.  Takes a while, possible hours, but works.
