TimeSlider settings on Web App do not match the TimeSilder settings on the underlying Web Map on ArcGIS Online
1157
12-19-2017 08:26 PM
AlexChen
On ArcGIS Online, I have a hosted Web Map that contains 4 hosted feature layers. Each feature layer has the same number of features and a "Date" field and was published with Time enabled. All the features in a featuer layer has the same date and time for that field.
They have the following attribute tables.
The web map was published and configured to allow time slider to show the feature layers with time.
Then I created a web app using Web AppBuilder out of the web map with a TimeSlider widget added. The TimeSlider on the web app has three time steps while that for the web map has four steps as above. Missing the last time step stopped the last feature layer from appearing on the web app.
I thought the TimeSlider settings on a web app should match the settings on the underlying web map. Any idea?
KellyHutchins
Esri Frequent Contributor
The app should use the info from the web map for its initial display. Is your web map public? If so can you share the link so I can take a look?
AlexChen
Thanks Kelly.
The web map is http://arcg.is/1GHbaD
The web app made from hte web map is http://arcg.is/1vC5zm
KellyHutchins
Thanks tested it out in a configurable app and it has the same behavior as the underlying web map. Perhaps someone in that space Web AppBuilder for ArcGIS‌ will know of a setting that will get the same behavior as the web map.
AlexChen
Thanks Kelly. I have posted the same question to the Web AppBuilder forum for them to look into the issue.
https://community.esri.com/message/739169-timeslider-behaviour-on-web-app-does-not-match-the-timesil...
