Thumbnail images in the Basemap widget do not appear in my web app
8531
15
09-12-2019 09:24 PM
ScottMcGee4
I have a  web app (built using the AGOL Web App Builder). The web app is shared with my organization (it is not public). I have added the Basemap widget, using four of ESRI's standard basemaps. In the Web App Builder interface, the thumbnail images for the basemaps correctly show up in the basemap widget.
The problem is that when I view the web app in a browser (not in the Web App Builder), the thumbnail images in the basemap widget do not appear. All I get is just four blank rectangles indicating where the thumbnails should load into. The functionality of the basemap widget is fine - when I click on one of the blank rectangles, it does in fact switch the basemap in the map display to the chosen basemap.
In my troubleshooting, I shared the web app with "everyone" (made it available to the public). With the app shared publicly, the thumbnail images do in fact appear in the basemap widget. So that's cool, but we don't want to share this app with everyone, just our organization. But if I share it with only our organization, then the thumbnail images in the basemap widget do not show up.
So it seems that this issue is related to some sort of permission/sharing problem. I have no idea how to solve this. Any ideas?
John_HaroldTabuzo
You can try to share the web app to "everyone" while retaining the sharing of the web map to a certain group of users for data security.
EdJuarbe
Reviving this thread since it's been a few months.  Has anyone found a better solution for this bug?  We just upgraded to Enterprise 10.7.1, and are seeing same issue.
VanessaSimps
We are seeing this same issue as well. We didn't have the issue until we downloaded WabDev 2.21  Has anyone else seen this and figured out a work around?
FY I @LeahClark
BillFox
MVP Notable Contributor
Did you try editing the widget in WAB and selecting the "Always..." option?
JenniferKuntz2
I am using Web AppBuilder developer edition v. 2.26 and I was having this same issue. I saw in my browser dev tools "404" (not found) errors for for images in <App folder on my server>/configs/BasemapGallery/. When I checked that folder, sure enough, the images were not present. I solved the problem by right-clicking Esri thumbnails and saving them with the same file names and location as listed in the browser developer tools. It was a bit of a pain but worth it if you'll be using the app a lot and don't want to use the setting that makes all basemaps in your AGOL organization visible (for some reason choosing that option doesn't cause the missing thumbnails).
ChrisRobinsonCOF
We are running into this as well in Web App Builder version 2.27.  I was reading in another forum that it might be because Imagery Services are not supported by the basemap gallery.  How can that be?  They have been around for what, at least 10 years haven't they?
Chris
