Okay where is the test connection Now set up? ArcGis? ArcGis Online? or is this a browser function?
This icon should be in your windows taskbar (next to the clock at the bottom right) if ArcMap is open. Just Right-Click on it to get the menu from my screenshot.
Hi, I am shown as signed in the File Pull down menu but the ArcOnline below it is grayed out. This is also true in the Add Data button extended choices. I am running ArcGis 10.1 on a Windows 7 platform. I suspec t our network firewall may be blocking the attempt. I do not have the test connection in the lower right taskbar tray.
Thanks for the help, I suspect I will have to visit our resident IT team and let them sort it out.
Cheers
Jeff Chartrand
This is strange
Please check this other thread and the links suggested there:
For me, the issue of sign in to ArcGIS Online only happened in Qa and Prod Servers.
The dev server was fine.
Turns out ArcGIS Administrator>Advanced>Manage Portal Connections was only pointing to http://www.arcgis.com/
So, I added AND connected https://www.arcgis.com/ and it worked.
Add the ArcGIS Online organizational domain in ArcGIS Administrator
https://support.esri.com/en/technical-article/000013176
Maybe the server internet options/proxy whitelist only allowed https arcgis urls in the higher environments (qa/prod) to be more secure.
I also added the appropriate Esri urls to the trusted sites.
These other resources also helped:
https://esribelux.com/helpdeskitem/troubleshooting-issues-adding-arcgis-online-basemaps-to-arcmap/
https://support.esri.com/en/technical-article/000013300
https://support.esri.com/en/technical-article/000011622
