Supported fonts
5492
06-29-2022 01:57 PM
JeffThomasILM
Is there anywhere we can find a list of supported fonts for content created/edited within ArcGIS Online and Pro-authored content that is published to AGOL? One that is updated regularly and includes some kind of matrix where these fonts can be used? E.g., pop-ups, labels, vector tiles, AGOL vs Enterprise/Portal, etc. Thanks!
ChristopherCounsell
MVP Frequent Contributor
List of fonts in ArcGIS Pro:
https://pro.arcgis.com/en/pro-app/2.8/help/mapping/layer-properties/text-symbols.htm#ESRI_SECTION1_5...
For Web Maps, you could go the standard fonts (I believe these are most accessible for web use). Article applies to Map Viewer Classic, so maybe the list of options has increased:
Arial, Courier New, Garamond, Tahoma, Times New Roman, and Verdana
https://support.esri.com/en/technical-article/000022500
Different parts of the ArcGIS API for JavaScript will identify what fonts are supported for the purpose. e.g. for the new Web Map Viewer (JS 4.x), the list of fonts when configuring a label would likely align to the list for the Labeling FeatureLayers in the developers site:
https://developers.arcgis.com/javascript/latest/labeling/
Related, you can embed fonts, and there is some discussion around how it is supported here:
https://pro.arcgis.com/en/pro-app/2.8/help/sharing/analyzer-warning-messages/20025-layer-uses-font-n...
The machine/server can support installed fonts. Some groups of fonts (type 1) appear less supported for web layers, meaning the Helvetica will be substituted for Arial.
It seems messy but I imagine it's a result of these font packages being maintained by third parties. I recall ArcGIS Server dropping a particular font in one release. Would recommend leaning toward the clean, default fonts where possible.
ChristopherCounsell
PriscillaHeuer
Here is the free web tool that can be used for creating customized text. For more details Click here....
SusanGarciaSusanGarcia
New Member
There are many, are you using them for a blog or something else?
