Style changes on custom vector tile layer are not appearing in web map viewer classic
1872
01-11-2023 12:51 PM
NSamu
Hello,
I am trying to update the style of a custom vector tile layer in web map viewer classic and the style changes are not appearing in the map viewer as I make changes. Is there something that I need to do in order to see the changes?
Nicole
RhettZufelt
MVP Notable Contributor
That is what I used to modify my vector tile layers published with share tab,  web layer, publish web layer, in Pro.
Also, there should be a link from the tile layer details page to the editor as well:
Not sure what permissions are required as I am in as admin.
R_
RhettZufelt
I believe you want to go to the Vector Tile Style Editor to make the changes.
R_
NSamu
Rhett, that's what I thought at first but it appears that this only works on ESRI vector tile maps and not user-generated tile layers.
NSamu
Okay, thank you--you just helped me connect some dots. The editor that wasn't working for me looks exactly like the one that you mention. I just accessed it from within Map Viewer Classic instead of the link you point to on the item's details page in AGOL. Oddly, I tried again and now it works. So, problem solved, I think:) There is another vector style editor called the exact same thing but with a different interface and different capabilities--that's the one that I initially thought you were talking about (snapshot below).
RhettZufelt
R_
