Square brackets are being inserted into an arcade expression
1119
10-17-2023 11:57 AM
ccowin_odfw
Hello,
So I have a table with URL links if a specific boundary has a PDF map available for folks to download. I created an arcade expression to add the HTML link. Not all boundaries have a URL so needed some logic to return nothing if there is no URL. However, there are two square brackets that are showing up and I have no idea why.
The pop-up:
The code:
if ($feature.CLOSURE_MAP != ''){
  if ($feature.Map_URL != '') {
    var urls = Split($feature.Map_URL, ', ')
    var links = []
    for (var i in urls) {
      var url = urls[i]
      links += Concatenate(["<a href=", url, ">View Map</a>"])
      links += ""
    return {
      type : 'text',
      text : links
KenBuja
MVP Esteemed Contributor
You are instantiating links as an array (line 6) but are using it as a string. Try this
        var links;
          var url = urls[i]
          links += ""
        return {
          type : 'text',
          text : links
KenBuja
        var links;
          var url = urls[i]
          links += ""
        return {
          type : 'text',
          text : links
