Spring Clean
1435
07-18-2024 06:40 AM
Labels (2)
OliverIshmael
We are concerned that across our hundreds of users a lot of data has been created that is not being actively used. Many of these files have a tiny storage cost implication but cumulatively it is very significant.
Asking users to review their content isn't always practical, so i wonder whether periodically we should download all data from ArcGIS Online and wipe the slate clean. Users could then add back the data they actually need.
How have other large organisations dealt with this?
jcarlson
A clean slate sounds nice, but the risk of breaking something is pretty high. Even if you add things back, everything will get a new ItemID, and any prior links or map configurations will not work.
We're not a big org, but here's how we approach it. You can use the built-in Administrative Reports, or else use Python, but every month or so, get a list of all your portal's content, along with how many views the item has had. Keep generating these reports, and after several months, you can combine reports into a single dataset.
At that point, you've got your items and their view count per month. You can calculate how much an item is being used month-over-month and get a derived percentage.
For items that are not being viewed (e.g., the growth percent is 0, no new views are coming in), you can more safely assume that these items are "stale". I would suggest establishing a formal policy in your organization that items which remain "stale" for more than, say, 6 consecutive months, will be archived and removed from the site.
This gives your users a clear metric and a policy to back up any decisions to remove content from the site. You can fine-tune the idea however you like.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
ChristopherCounsell
MVP Frequent Contributor
No this is not practical and is an anti-workflow.
Start with user training. If they want an account, they do training and get guidelines. This is the quickest and most effective solution but I appreciate not as easy after the users have all been provided access...
For administration start with identifying the items and users. Here's a guide on understanding storage and credits:
https://esriaustraliatechblog.wordpress.com/2021/06/22/which-arcgis-online-items-are-consuming-the-m...
From there it's a bit more dependant on your organisation and needs but you could look at different aspects to identify if it's in use or not:
  • Item sharing
  • Authoritative tags
  • Usage
  • Metadata completion
There are some reporting tools inbuilt but can be further extended by python.
