Special characters in .shp attribute table
3668
08-31-2012 04:44 AM
nita14
Dear All,
  I would like to import zipped shapefile to my ArcGIS Online map. The original shapefile field names and field values contain special characters (used in many european languages) and they do NOT display correctly in the pop-up window. I think, the issue is the ArcGIS Online default encoding format. Does anybody have same issue? Any help is appreciated.
Below sample pop-up[ATTACH=CONFIG]17403[/ATTACH]
Adam
MikeMinami
Esri Notable Contributor
MikeMinami
nita14
Dear Mike,
  Thank you for your answer. It works great!
Kind regards,
Adam
shivamparashari
I tried removing the special characters from the table but it didn't work. Can anyone help ? 😞
