Sorting for a Popup in Web Viewer using an Arcade element
2315
09-21-2022 04:36 PM
John_Shell
I am trying to figure out how to sort my field called "Name" in ascending order in the arcade element expression. I wasn't able to find an HTML tag and I tried used using Order By but I couldn't get it to work. Any help would be greatly appreciated.
Thank you,
John
Choose a template from the Templates tab to get started with creating different content types for your pop-up.
To learn more about using Arcade to create pop-up content visit:
https://developers.arcgis.com/arcade/guide/profiles/#popup-element
var areas =FeatureSetByName($map,"Neighborhood Council Districts (Tacoma)");
var Onefifty = Buffer($Feature, -150, 'feet')
var countp = Intersects(areas,Onefifty);
var result = "";
for (var item in countp){
var name = item["Neighborhood"];
var url = item["URL"]
result += `<a href="${url}" target="_blank"><span style="color:#287fb8;"><u>${name}</a><br/>`
return {
type : 'text',
text : result
Tags (3)
KenBuja
MVP Esteemed Contributor
What happens when you change line 3? I'm assuming when you say "sort my field called 'Name'", you mean the 'Neighborhood' field.
var countp = OrderBy(Intersects(areas,Onefifty), 'Neighborhood ASC');
var result = "";
return {
  type : 'text',
  text : result
KenBuja
var result = "";
return {
  type : 'text',
  text : result
John_Shell
That code worked perfectly.
Thank you,
John
