Sort Options for Related Tables in New Map Viewer
1257
04-29-2021 11:32 AM
EricEscobar
Is there a Sort Options field available on the new map viewer for related tables?  I have a layer with a related table and would like to sort the date field in the related table so that all of the dates are ascending when records are being viewed on Field Maps.  In the map viewer classic, this option was available at the bottom of the Configure Pop-up pane and now I can't locate this option on the new map viewer.
Thanks!
JenLangevin
I would like to do something similar. Did you find a solution?
EricEscobar
Within the new map viewer, I did not.  I used map viewer classic to set the sort option on my tables.  I believe the new map viewer still doesn't have this functionality.
