Some Layers not Loading in New Map Viewer
843
01-04-2022 06:18 AM
ChangNi1
Hi all!
I've run into an issue when opening my maps (built in classic map viewer) in the new Map Viewer.
Say we have three layers: A, B and C, all based on the same hosted feature layer, just symbolized differently:
  • A is symbolized with a custom Arcade expression, and uses the Shape symbols in Classic map viewer
  • B is symbolized with a categorical attribute, and uses custom images as symbols
  • C is symbolized with a custom Arcade expression (different from A), and uses custom images as symbols
Only B displays normally in the new map viewer.
It will be really helpful if someone can provide some pointers on possible cause and solutions.
Thanks!
RussRoberts
Esri Notable Contributor
Can you share the map and we can take a look? thanks!
