showing one to many values in a pop up
1625
03-28-2017 09:34 AM
ScottShenberger
Good Day
 I have a feature class in AGOL that is a join between a polygon layer and a table. The join is 1:M in this case one inspector has many inspectors under them. I would like to be able to configure a pop up to allow a user to click/tap on a polygon and be able to see not only the lead inspector but the inspectors under the lead without having to click the "next" arrow in the popup. Is this even possible in AGOL at this time?
Tags (4)
KellyGerrow
Esri Alum
Check out this documentation for strategies to display related records in pop ups: Configure pop-ups—ArcGIS Online Help | ArcGIS
You can set up pop ups so that related records are displayed within the pop up.
-Kelly
KellyGerrow
Esri Alum
-Kelly
