Show unlinked text in field of popup
704
12-13-2022 10:18 AM
TimHayes3
I have an attribute expression that is a conditional statement. In my code below, I need to have 'TBD' shown as not linked text. Currently, when this expression shows up in the popup, 'TBD' is linked to my webmap. Any ideas on how to ensure 'TBD' does not show as linked text?
var link = 'www.myurl.com'
if ($feature.RESOURCETYPE == "Type 2")
return link
if ($feature.RESOURCETYPE == "Type 3")
return link
else 'TBD'
RhettZufelt
MVP Notable Contributor
You should look at the if syntax in the documentation.  you are missing the curly brackets enclosing the result part.
Since both Types will return the same thing, could also just see if it is included in a list and return what you want:
var link = 'www.myurl.com';
var field= $feature.RESOURCETYPE;
var arr = ["Type 2", "Type 3"];
if (Includes(arr, field)){
   return link
   } else {
   return 'TBD'}
Could also use the Decode function (though, not as easy to add to/modify the list:
Decode($feature.RESOURCETYPE, "Type 2", "www.myurl.com",
                              "Type 3", "www.myurl.com", "TBD")
R_
RhettZufelt
   return link
   } else {
   return 'TBD'}
R_
